Old 10-07-2007, 07:56 AM
mad.sculpture mad.sculpture is offline
mad.sculpture is on a distinguished road
probably a stupid question
Hi folks,
if i go shopping on ebay for complete linear slides to try to make a mill with the least machining and individual parts sourcing how much of an issue is it if the units gearing is not the same ?
You see what would make a complete axis so simply but the chances of you getting an idential ballscrew/complete slide any time soon are minimal.
I've read several cnc on a budget articles and if your building an ideal machine you'd make steps/distance on each axis identical, however other than this factor some of the ebay surplus looks very tempting.
How much of the software you guys use allows different travel/pulse on each axis ?
Didn't know what forum, probable software cure to hardware problem.
I want to end up 4 Axis milling organic sculptures so i don't realy need super
accuracy but it would be nice ...and if i had to i could stretch the model by certain percentages to compensate, but thats such a sloppy solution
Cheers
