Old 10-04-2007, 03:30 PM
JerryFlyGuy JerryFlyGuy is offline
Moderator
JerryFlyGuy is on a distinguished road
No question, the harmonic drive [don't let the name scare you] is the best route to go. ZERO backlash ZERO.. which is a big concern w/ worm gear stuff [which can hit zero if adjusted regularly to keep them there]
Harmonic drives also have high reduction ratios [100:1 is no big deal] which is also something you'll want for two reasons. 1. You'll want to be able to absorb large force numbers and yet have a reasonable drive size. 2 Positional accuracy. If you have a standard 200 step stepper w/ a 100:1 drive you can position the table to w/in 0.018degrees. If you had a 10 step micro step drive it'd be 0.0018 deg. [Now we all know micor stepping isn't that accurate.. but in theory]
If you had a 500 line encoder on a servo it'd be 0.0018deg.
Anyway, you get the idea..
Got any CAD shot's of the machine?? How big is it going to be when completed? Intended use?
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
