Sorry guys. I did not consider that. My servos are using 9-pin serial port connectors for the encoders. I assumed that the pin numbers for these connectors were standard, but it seems not. After checking the spec sheet on my servos pin 1 for the encoder was actually pin 5 for my cable (the gender changer switched it around). Once I wired the four encoder leads in reverse, everything worked fine. |
