I guess the only bad mark I can give this machine is the slightly noisy fan on top of the spindle motor. It runs even when the spindle is not on and is a little annoying if you are just setting up the machine. I may add a temperature relay to disable it if the spindle motor is cool enough. Once the mill is running it is not so noticeable and the machine in general is not noisy. I have not used it much yet but everything else is great.
Jim |
