Always you asked about a problem the first answer is "send me video or photos" .
The numbers not always are the same for both axis, if you see the gear or pulley reduction could be different for this reason you will have to experiment different numbers. Have you draw the circle and after look at the measure tool? There you can change the measures, at this point if you continue geting the oval thet will confirm you have the wrong number on that axis.
Luis |
