Rotating nut | | Either nut or shaft rotation will move the gantry. Seems easier to use rotating shaft from my limited perspective and gears on the end with some give on gantry threads-this may be a no no. You can then change end grear ratio-but guess you could use a variable speed drive too..... Seems each drive is fine. jmho,pw |
