  #11   Ban this user!
Old 09-30-2007, 11:26 PM
Lucan Lucan is offline
Lucan is on a distinguished road
Started work on the bed. I see most people call this the X axis, but I'm calling it the Y now. This seems to follow the labels in V-Carve, and Mach. The default arrow key definitions in mach also make it move in the directions you would expect.
Anyway, ran into a slight problem. I pulled the "X Axis Torsion Box Long Run Braces.dwg" into V-Carve, which had the brace split at a point that I could cut. I didn't catch the fact that the center cutouts weren't there though. I didn't notice until I already had most of the torsion box glued up.
I didn't think it would be a problem, but once the top and bottom skins are on, I'll have no way to get at the ends of the bolts that hold the end supports on to put the washers and nuts on.
At this point, I figure I can either cut access holes in the side with a jigsaw, use t-nuts on the end piece, or just bolt them on and then add the top skin with just brads and no glue in case I need to take the gantry off for some reason. Think the top skin will be strong/stable enough without glue?
