Originally Posted by mugabe i guess the design could be done better if metallic frame was built welded (or bolted ) as one piece and then cemented . At least cement shrinkage could better be compensated .
opinions ? |
At least you can cast something bigger than the door way.
Comes with the house!
Wife says "how will I sell it when you die?".
Turn on the spin drier while concrete is setting (assuming house not on a slab
or drier not mounted on pillars).
