Originally Posted by sblack I ran into a problem with the Z nut - one of the horizontal bolts that attach it to the Z carriage hit one of the vertical bolts that attach it to the support blocks below. I also notice that sometime when I drill the HDPE the drill goes off at an angle, even when I drill in a milling machine! I perhaps fed too fast, did not take the time to center drill or something - dunno, but most frustrating. Any hints or pitfalls to avoid when drilling in HDPE? My bit was sharp and I was holding everything very square. It is tricky stuff to deal with I find.
I cleaned the pipe rails last night and once the Z axis nuts are dealt with I will assemble the gantry. I forgot the 1/2" bearings and ordered them last night. This should come together in the next 2 weeks as all the difficult stuff is done. |
Is that you Scott? This is Bill Griggs. I am also building a Router. Mine is a slightly redesigned Hybrid 4'x4'.
Bill
