Old 09-27-2007, 11:27 AM
machrychar machrychar is offline
machrychar is on a distinguished road
Trouble using R style insert.
Hi everybody,
New on the forum as well as on machining stuff, I'm having trouble with G71 cycle on Fanuc 21T.
I want to profile an arc (120 degrees, radius 25 mm) with a R style insert. I'm using G42 to correct the tool nose radius (4 mm) but when it passes the 90 degrees point, that's the back of the tool that cuts the profile.
Shall I change G42 into G41 at that point and so it might correct the back of the tool?
I'm a bit lost!
Hope all this is understandable enough in English.
Regards
JL
