Originally Posted by gus if it still says that, you are not homed
power on
"CE"
Power enable
feed rate override at ~100 percent
cycle start [wait]
cycle start[wait]
cycle start[wait
cycle start[wait]
cycle start[wait]
cycle start[wait]
As each axis is homed, with a max of 2 moves per axis, that line should disappear
until it is homed, it will do nothing else |
Gus...please help me out....when I push the cycle start button on my series 2 intact 2 it does nothing...should it buz or fart or spit....also the feed rate knob is so sensitive that simply touching it will cause a jump from 100 to 80 or 120 etc...this is the first time I have tried to start this machine...I have no idea what behaviour to expect....not certain if I am dealing with a program issue or hardware problems....also a note the air spindle brake will not switch to the off position help....and yes I have read the manual....but it goes about everything as though you are starting with a working machine.
