  #12   Ban this user!
Old 09-21-2007, 08:39 AM
lamicron lamicron is offline
lamicron is on a distinguished road
The focusing point should be in the top of the plate you are cutting.You can make a caliper (acrilyc ) with the thickness (heigth) and you use to measure for each different plates thichkness.
The beam flows like X and the focus point is the center where the lines cross, (that is the finest Point) if you are below or over that point you will get a wider path (wider point)
