Old 09-21-2007, 06:24 AM
jrrdw's Avatar
jrrdw jrrdw is offline
jrrdw is on a distinguished road
Originally Posted by flyman219 View Post
Thanks for the help, I'm going to grind down the tool holder so it will fit in the tool rest. Next question, the tool holder has the 1/4" bit set in it at a angle rather than horizontal to the work. Is there any threads on the forum that shows what kinds of angles are needed to sharpen the bit. I've seen the angles for the bits that mount dirtectly in the tool rest but not with a bit in a tool holder, left, right, straight etc.
Mike
I would sharpen the bits the same way no matter what tool holder your useing. When it comes to shaped cuts, grind the bits acordingly.
I like this smily
Make sure you clean my wrench before you put it back into my toolbox.
