Originally Posted by lamicron Did your machine seller tell you the heigth? if not , try to make some laser points at different heigths, whenyou get the finest , sharp, tiny one, measure it from the top to the plate and then use it ever.
Luis |
I dont know the exact height, but when i tested this: focusing point was below the cutted part(this is only waht i think?) there was less smoke on the cut rail, and it was spreaded smooth and not so far from the cut rail, i was wondering could this be the focusing problem?(should the focus be on the on the bottom of the cut part or on the top?)
