Originally Posted by flyman219 Here I am again with another beginner question. I have got my HF 8x12 on the bench and running now and noticed the tool holders that came with the used machine are to big for the square cutter rest. My rest can take about 3/8-1/2" and I was wondering if I could just grind down the top side of the 1/4" tool holder to 1/2". Or, would I be better off just getting some indexable 3/8" cutting tools and not bother with the tool holder. I'm looking at the 5 piece 3/8" set that Littlemachineshop has for about $33. I also got a quickchange tool post with the lathe that will accept the 3/8" cutter bits. Thanks for your time
Mike |
You know you can buy HSS, and its the right size already, although may need to shim it up depending upon your grinding skills.
chris
