Old 09-18-2007, 04:36 AM
JonasC JonasC is offline
JonasC is on a distinguished road
First of all I wonder if you would like to discuss how you could outputthe command for blockskipping in ProE (to the postproc) or whether you want to know how to handle the actual programming in ProE (or both?)
With regards to output a command to the cl data for the pp to recognize that you want a certain comand(block skip) the easiest way would be to just insert a CL command. This could be done "manually" in ProE or via a mapkey or a copied nc seqwith just this info. You then need to configure your post to handle this command.
If you are referring to the actual programming of theese 2 similar parts there are quite a few ways to achieve this but I would need so see an example. If it isnt to high a security issue feel free to contact me and I can have a look at them. And I dont mean that as an consultancy suggestion. Free of charge of course in the spirit of this board.
Thanks/ Jonas
