A double row UNSPLIT outer ring with a set of SPLIT ROW inner rings could very well be preloaded - it depends what sort of "preload" is applied if/when the inner rings are shoved together until tight.
The bearing pictured in post 1 is definitely a traditional, non-preloaded double row with, typically a combination of radial and axial clearance. |
