Originally Posted by jim_stoll Cool - thanks for the sample HuFlung! I'll try that out and play with it a bit and learn some things!
I'm not actually using Mach as my driver program. I use EMC, but for whatever reason, there doesn't seem to be an EMC post for Dolphin. I've been using the TurboCNC Post - basically because its simple and I can pretty much understand it, plus, EMC finds the gcode generated by the TurboCNC Post to be palatable - it gags on some gcode generated by the Mach2 post. The Mach2 post seems to have some features/capabilities that the TurboCNC post is lacking though, and I suspect that I'm going to end up with a hybrid of the two before all is said and done. There have GOT to be folks out there using Dolphin to generate gcode for EMC-controlled machines, but darned if I can find an EMC-specific post for Dolphin!
Thanks Again! |
Is the customized post we made for you working correctly?
