you are right
Thats why the extended 2.2" headstock is for
it will increase the distant between the vertical column and the cutting bit. Now i have around 6.5" of Y axis cutting distant. I can continue to add another headstock to it to increase the cutting distant, but at the expense of have a very heavy head, which may cause it to droop.
