Old 09-12-2007, 02:14 PM
mxtras's Avatar
mxtras mxtras is offline
Silver Member
mxtras is on a distinguished road
I think the limit is more than 50 lines. It's more like 1000 lines.
As far as the other issue - I have yet to be able use the code right out of the box. I always have edits. I will go through the code and do a search and replace to add a blank line whenever there is a Z or rapid (G0) move, then scan the code manually and make sure it is correct. Usually, the initial moves are a bit flakey but the internal moves are OK, but that's not always the case.
The 60 you are seeing is likely your retract setting for rapids - I am not sure of exactly how to change this in the newest version - I am now using an older version of LazyCam - I tried the latest and greatest and did not care for it (yet). I will give Art a few more revisions, then I will dive in.
Scott
Consistency is a good thing....unless you're consistently an idiot.
