Originally Posted by springlakecnc For steppers, why not look at keling? you can get the motor AND the drive from the same place, and they can help match the package for you.
I built many cnc machines, and when using components that come from differn't places, if something don't work right, the drive manufacture simply point their finger at the stepper/servo motor manufacture, and the stepper/servo motor company points their finger at the drive manufacture. No one takes the blame. If you get them from the same place, you have that potential problem solved. I believe you can get the power supply from Keling also, now you have that matched with everything also.
I installed some Kelings and liked them.
Good Luck,
Buck |
Above 8 amps keling does not have a drive to push the motors, the largest I saw was 7.8 amps.
Jason
