I'm not sure if this is true but i have heard from some plasma reps. that the THC for a conventional plasma is different from what you would need for a hydefinition plasma. anyone have any thoughts on if this is trua, and if so what those differences might be. |
Hydefinition? If you can afford that you can afford the 15,000 THC that goes with it! All the THC solutions quoted here have been for standard plasma.
Make sure HyDef is what you want. It's really good on thicker material >3/4" but won't buy you a whole lot more on thin (>12ga) stuff.
It still won't give you laser or even AWJ cut quality. In fact conventional OXY-ACET on thick material is hard to beat.
What are you planning on cutting that you think you need HyDef?
