The nmbt quick change tooling has 1/2 13 thds so instead of the collar and a wrench i use a drawbar. if you use the collar the toolholders you get have to be specific to the quick change you have, as the the flange thickness that the collar use varies by brand. not an issue with the drawbar, you can use any nmbt 30 toolholders |
