When engraving stick figure text you need to make a couple of changes.
you need to use contour2d, on the cut control page set cut method to "on" and while you in the contour 2d process pick the "options" tab and set gouge check to single. NOTE when you are done, set gouge check back to full and cut method back to climb or conventional. |
