Go to Setup>table setup. On the axis setup tab, there is a depths section. Travel is your rapid height (default is 1). Change the Normal Cut to a negative number (the depth you want). If you want to use different depths, set the Deep Cut as well. You'll have to use a layer name for deep cuts and specify the layer in the .dxf options. These settings control your cutting depths.
I don't use KCAM, I just have a copy of the Demo. But, I found what you're looking for in the help file, just had to dig around a little.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
