Personaly i think PSI (or Gph) is way more important than flow..
i go for at least 50psi on a fully enclosed commercial machine but since we are talking hobby machines that may or may not be enclosed i would say at least 15psi.
And if your using a 5 gallon bucket like alot of people are using then the flow has to be in line with your source, as you cant flow more liquid than you have for supply.
As for your fine mesh screens, you will have to play with those, as the finer the mesh the sooner you have to clean them.
I use 1/8in hole mesh for my commercial machines and nothing for my hobby machine.
OH and really important what type of pump your using. Must be able to pass solids (impeller pumps are good for this) Gear pump is a NO_NO and diaphragm pumps need really good pre-filtering other wise diaphragm will get punctured.
__________________ thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!" |
