Old 09-07-2007, 10:14 AM
Skuzzy Skuzzy is offline
Skuzzy is on a distinguished road
So do you find you need to adjust the coolant flow direction often? It is not something I had considered. I figured I might have to adjust the angle to be sure the end of the bit was getting good flow, but that was about it.
I am mounting my mill in the enclosure this morning and will start working on the cooling system and getting all the cabling run to the controller.
I am also using a DC driven pump so I can control the flow. The head is rated for 300GPH @ 8psi into 3/8" ID @ 0" lift. I have two of these if there would be a reason to run a second flood line.
Anyone know of a reason why this would be required? I see some use two flood lines while others use one.
