Old 05-11-2004, 04:37 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is online now
Splint, There is also another source of voltage spikes that I have seen cause problems if not taken care of, that is back emf suppression of relays,solenoids, contactors etc, even if optoisolators are used for switching.
For AC devices a resistor/capacitor in series combination is used across the coil, the values depend on the size of the device, also on AC a varistor (voltage dependant resistor) can be used. On DC a diode should be wired across the coil in reverse bias to the DC supply i.e. anode to DC+. The diode will delay the opening slightly of the relay, but this is not usually a problem.
Al
