Old 08-30-2007, 09:11 PM
Chuck Reamer's Avatar
Chuck Reamer Chuck Reamer is offline
Chuck Reamer is on a distinguished road
An easier and cheaper way would be to get a gasket or seal shop to make you a cutting die. They use a piece of plywood that has strips of sharpened steel stuck into a router grove in the shape of your cuts. They are pretty damn cheap usually under $100, and work like hot damn. We have used them to cut sheets of rubber and its the only way to go for stuff like this.
An aluminum die with a plastic punch would probably leave a pretty sloppy, unprofessional looking cut.
Live free or die
