Hu,
Sorry I was trying to find a quick fix. But to no luck. It appears that Auto save is broken.:frown:
Does auto save work if you use the default user? Mine does'nt work even using the default user.
Also did your toolbar and layer settings move when you tranfered the settings file?
Look at your setting.ini file for the different user names you have and see what size they are. Default starts out at about 12kb and the other customized files I have are about 18kb.
I have noticed that if you use the drop down and create a new user, then go and copy the setting.ini from another file into the new user in windows explorer, it about doubles the file size. So it seems that the old setting.ini does not go away, that it just gets added to.
I'll make the call to OneCNC about the auto save.
