Hi Splint,
I believe the mystery device is called an optoisolator. If I understand the concept correctly, I believe the circuitry on either side of the optoisolator runs each on its own power supply. This provides the seperation of the voltages. The optoisolator then translates a signal from one circuit system to the next by means of light.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
