Check out the DC supply on this machine. If both CRTS are unstable your +12vdc could be the cause. You will need a digital volt meter. Measure at power on and monitor voltage (both ac & dc). check again after display is stable. if there is a lot of ac on the dc supply it needs to be replaced. |
