The data you say is missing, is that not due to calling a 'modal number' function, whose express purpose is to eliminate a number that is the same as that on a previous line? That is what modal means, but I do not think that the Bandit is going to accept that as a legit arc movement, so all 4 values XY/X/Y must be expressed for every arc (I think you know that). So anyway, I suspect you do not want to use a modal function in this case to discover modal numbers.
Modal number discovery is fine for linear moves, but not circles, in Bandit. This is my WAG.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
