Old 08-23-2007, 04:40 PM
Oldmanandhistoy Oldmanandhistoy is offline
Oldmanandhistoy is on a distinguished road
Originally Posted by iamscottym View Post
I am looking to purchase a small mill, because my college's machine shops are only open 9-5 and I find myself needing more time to work. Anyhow, I'm planning on getting an X3, because it's about the biggest machine I'll be able to move around. I would also like to get a lathe, but getting an X3 cnc'ed with cnc fusion's ground ball screw kit, plus geckos, Mach 3 and a cam package will pretty much tap me out for the time being.
Most of my work revolves around a guided rocket I'm building, and so I need to be able to turn nozzles. I'll be using 2" OD delrin in a step collet. Would anyone anticipate power issues with an X3? If so, how powerful of a motor would you suggest? I'm planning on adding a belt drive to get a little more rpm range anyhow, so I'm considering a BLDC motor. I've been seeing some really powerful outrunners lately that I'd love to play with.
Thanks,
iamscottym
The simple answer to your question is imho yes there will be enough power in a 600+ Watts spindle. I have turned 2” Delrin on a mini lathe with a 350W motor without problems. As I am sure you are aware depths of cut will need taking into account.
John
