Old 05-06-2004, 12:08 AM
Kookaburra's Avatar
Kookaburra Kookaburra is offline
Moderator
Kookaburra is on a distinguished road
Paul,
That is very strange, I have never heard of that before. All I can suggest is that you try uninstalling it and do a fresh install, make sure you have nothing else open during install. You could try to do a shutdown and restart before running it for the first time. Other than that I will look into the possible cause for you. This is the first ever time this problem has surfaced so I'm sure there is a simple problem. If it still happens after a re-install I will send you a fresh install version tried and tested on our XP systems.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
