Thread: Tormach Cnc ???
Old 08-21-2007, 01:24 PM
zephyr9900's Avatar
zephyr9900 zephyr9900 is offline
zephyr9900 is on a distinguished road
Originally Posted by twocik View Post
Basically can I use all of the existing software that I have now or do I need to buy new (Cad Cam and Control software)?
You can use your existing CAD and CAM software. I'm using Sheetcam and Meshcam, and have tweaked posts for both of them that I use. The PCNC control software that the Tormach comes with is a customized version of Mach3. It needs a fairly hefty PC (specs are in the PCNC1100 manual on Tormach's website--quite worthwhile to read through 2 or 10 more times even if you've read it already )
Is this a ready togo CNC (without having to modify anything) machine?
The Tormach was designed from the ground up as a dedicated CNC machine. No handwheels, no quill. If you haven't already read the "Personal CNC Design_v1.pdf" on the Tormach site, do so. It is a really good design analysis. The Tormach has its warts (my stand leaks coolant, for example), but I love it. It is solid and accurate. You can use it right out of the box and do wonderful work with it, especially if you have previous CNC experience (which you apparently do since you already use TurboCNC.) I had a Sherline CNC mill for 8+/- years which gave a good grounding in CNC, but moving up to the Tormach was like going from a Bobcat to a Caterpillar D6
Best regards,
Randy
