  #10
Old 08-18-2007, 08:50 AM
widgitmaster's Avatar
widgitmaster widgitmaster is offline
Gold Member
widgitmaster is on a distinguished road
Actually, I have thought of that! The only problem other than the noise which you have mentioned, is that all the wet / dry shop vac's are made from pre-molded plastics. None of them will adapt easily to the rectangular opening!
When I found the inline blower, it looked way easier to adapt to the plate! Plus, I can run the exhaust line out the window!
Now, I have looked at all the different shop vac's, and they have a CFM lower than the inline blower, which tells me that it should work fine! All I have to do now is shop around to find the lowest price, buy one, and adapt it to my grinder's tank unit!
Thanks Ian,
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
