Dear Fish,
This problem is found with many DNC Softwares running in Windows Mode. They need you to delay (as you have set) between each line Transfer.
However, your DNC will work with True Software Handshake (XON / XOFF), if you use. DOS Based Software. One Such software is 'PCIN' from Siemens.
It is available with Siemens Service Persons. To Use it as DNC you must boot your PC in True DOS Mode (Press F8 while Booting & select 'Command Prompt').
With Fanuc Controls of various types I have used it at a boudrate of 19200 without problem.
SMA
__________________ smabhyan |
