Old 08-14-2007, 11:14 AM
AustinT AustinT is offline
AustinT is on a distinguished road
Originally Posted by mxtras View Post
I guess you are suggesting to use the wire as feedback rather than using it as an aid in mechanical construction?
Scott
Yes it would be feedback. The wire would only be used during the setup of the rail. The machine during setup the machine needs to know a linear distance down the rail and a deviation from the guide wire. This information is used later during the operation mode of the machine. Suppose a straight cut needs to be made down the x axis length of the machine. Traditionally we would only use the x axis servos or steppers to make the cut. Now we would know that during the cut certain locations along the rail are not straight and we would use the y axis steppers or servos to make up the difference.
