Old 08-13-2007, 02:41 PM
zephyr9900's Avatar
zephyr9900 zephyr9900 is offline
zephyr9900 is on a distinguished road
Originally Posted by bnalls View Post
The Slide screw insert on the lathe table requires the motor to be turned many times before it changes direction.
Hi Brian, something is definitely out of adjustment with your lathe. It should be possible to get .003-.005" (.08-.12mm) backlash with the stock lathe.
My lathe is a stock 4400 with CNC, and I can regularly turn parts to .001-.002" tolerance (backlash measured and compensated in TurboCNC.) If your lathe is CNC, are you sure that the leadscrew support bearings are adjusted with no play?
Best regards,
Randy
Last edited by zephyr9900; 08-13-2007 at 05:35 PM. Reason: Junk about backlash adjustment removed. Thinking about my mill...idiot me.
