turbostang,
You might want to consider a VFD over a rotory phase converter. Reason is most VFD's can run off single phase. The plus is what ever 3ph motor you want to control will also have variable speed. That way you won't need to change belts or gears as often when serching for that perfect cutting speed.
Trevor |
