The motor does lock up when I connect the picstep to the 4 axis interface.
I am pretty sure I have done the enable setting correctly since it works with the two others pictstep (first connected a working picstep to the x axis connection on the interface and that worked, then i connected the faulty picstep to the same x axis connection and then it doesn't work) |
