Darebee is right squared corners are made with broaching cutters, EDM's or filing.
You could try to cut the pocket and then come back with a smaller diameter cutter to lessen the corner radius but it will still require broaching or filing to get them truely square. If you can get the radius as small as possible first it lessens the amount of filing needed to square things up.
Bowman |
