Originally Posted by DEAN Can someone outline the procedure to do the necessary backups. I have a TL-1. Thanks in advance. |
This is the procedure to save everything in one go I think.
Put floppy in and do this sequence on the keypad.
LIST PROG
END
ALARMS
Type "DEBUG"
WRITE
POSIT
PAGE UP to a screen that says POS-RAW DAT
Type in the machine's Serial Number
F2
Will save everything.
An alternate way to save Parameters and Settings separately is:
LIST PROG
PARAM (F2 and F3 should show on the Parameter page when you go there from LIST PROG.
Type in Serial #.PAR
F2
For Settings you go to the Settings page from LIST PROG and use .SER after the Serial #.
