Originally Posted by Al_The_Man One method, which depends on whether you can tolerate it cosmetically, is to use a small diameter tool for the final finish on the outside of the pocket, and when the corners are reached the tool moves out a small distance at 45°, just enough to take out the normal radius that is left.
This depends alot on your application.
Al
I`m not sure I understand how that works?
