Old 04-28-2004, 07:36 PM
ger21's Avatar
ger21 ger21 is offline
You can give a motor up to 20x to 25x the rated voltage. You also need to make sure your driver can handle that same voltage. I think 70V is the max rating of Gecko 201's, which are probably the most popular drives you'll see here. (rated over 30V, anyway) There is some good information in the white papers at http://www.geckodrive.com/support.htbml?order_id= .
