Rhodan has requested that this be added.........
You should mention in the power supply descriptions that amperage drawn is dependant on load and that the power supply will deliver only as much power as the circuit requires.
A common question in electronics is "My circuit needs 1 amp but I can only find a 2 amp power supply, will that work or is it too big?" |
