I got a likely problem using Hypertherm machine. It didn't start the arc between two part. I meant to say the torch cut one part and then when try to start a new part it doesn't start the arc. The problem was solved when I increased the time at CNC for start arc. Increase this time to above 6 seconds and then you 'll get the arc. I am taking in consideration that the program is okay.
Alex S.A |
