When I had finished I adjusted the gib with a dial indicator at each end of the slide - between table and slide etc until the play with a heavy push and pull was less than 0.0003 - not counting the flex/spring of course. this is 'across' the gap - not along the screw - then the slide should still be free to slide. |
