That actually will change the scale of your dimensions, but not the scale of the actual drawing. What you will want to do is select the enities that you want to scale, then you will go to "Edit" and choose "Cut". Then you will go back to "Edit" and choose "Paste". Then right click on the screen and it will give you options including scale which is where you will put in the 1.5. I hope this helps. |
